Hey all -
Should we be recommending that our customers run this workflow? I do see that upgrade is listed in the DDB health page, but not sure if this is required or what the best practice is???
Melissa
Hey all -
Melissa
I would say yes in most cases. v5 (technically v4 Gen2) introduced the following features:
The only scenario I can think of that I would not recommend it would be older MAs that are already performance bound or not using NVMe or SSDs or are currently tight on space or are experiencing high Q&I times for their DDB drives as v5 does introduce the ability to spawn new DDBs in the event the existing ones are over burdened and thus would potentially require additional space/usage.
Below is a video with a deep dive of the changes between the two if you are interested.
Tech Talks - On-Demand Learning Library - Confluence (atlassian.net)
About NVMe SSD optimization, I can see on documentation the following informations:
The new deduplication generation introduces a built-in optimization for deduplication databases hosted on NVMe SSD storage technology. If the NVMe card is not detected properly, it can be set manually. When NVMe is used, the number of threads used is increased from two (2) to eight (8).
How can we checked Commvault detect the NVMe card?
Kind regards,
Jeremy
Kind regards,
Jeremy
Good question! We ran all our MAs virtualized and use NVMe based arrays. So there is a big chance that in our case this is not detected. So which report of console gives access to this information so we can determine if we need to set it manually. As for DDB migration to the latest version, why is this still a manual process? Why can't Commvault just upgrade the DDBs automatically to the latest version or adopt the UI as such that it displays a recommendation stating that the specific DDBs are eligible for an upgrade to the latest version.
I was searching for it in the documentation but couldn't find anything related but Google turned out to be my friend → https://commvaultondemand.atlassian.net/wiki/spaces/ODLL/pages/358580314/Deduplication+V4+Gen+2+V5
NVMe SSD Optimization
The auto detection didn’t work every time, so the enhanced behaviours just became default.
Regardless of what disk the DDB is sitting on your should now see this in the SIDBEngine.log:
236 1a3c 11/03 21:27:49 ### 1-1-2-1 LoadConfig 360 Max Threads [16], Backup Threads [8], Pruning Threads [8]
236 1a3c 11/03 21:27:49 ### 1-1-2-1 InitShared 93 DB files are on an SSD disk.
Let me know if this answers your question.
Hi
Thank you for your return !
I just checked on my configuration, setting max threads is equal to [8], on your screen is equal to [16], what do you think? Optimization is it correctly applied?
12308 2b38 11/17 07:12:44 ### 35-0-35-0 InitShared 93 DB files are on an SSD disk.
17068 2f0 11/17 09:02:17 ### 35-0-35-0 LoadConfig 322 Setting max threads to 8
17068 2f0 11/17 09:02:17 ### 35-0-35-0 LoadConfig 326 Setting max backup threads to [4]
17068 2f0 11/17 09:02:17 ### 35-0-35-0 LoadConfig 330 Setting max pruning threads to [4]
Thank you for your support, I really appreciate,
Kind regards,
Jeremy
I have another client with 11.28 versions, the DDB is a fresh install on a NVMe disk and the setting max threads is equal to [16].
So I don’t know if it’s due to the conversion or the Commvault versions.
