Hello there,
I’m have a minor issue, I cannot delete unused Mount Path, since it’s used by DDB. There’s a few of MPs under Disk Library dedicated to this DDB. In the DDB properites I can only remove whole Disk Lib, which is not the point.
CommCell says that in order to delete this MP, I need to delete each Storage Policy Copy which is referencing to this Disk Lib. It’s not an option neither.
Logs are saying something similar:
EvMMConfigMgr::onMsgConfigStorageLibrary() - Error a470, Mount path is used by a Deduplication database.] occurred while deleting the mountPathhxx]
###### MLMMountPath::deleteMountPath() - :mlmmountpath.cpp:6170: Failed to delete mountpath :xx] due to error 470, Mount path is used by a Deduplication database.].
###### MLMMountPath::deleteMountPath() - :mlmmountpath.cpp:5593: Failed to delete MountPath from database for Id 5xx] due to error Mount path is used by a Deduplication database.:470
Do you have ideas, workaround to delete single MP in that situation?
