I need to move backup from 1.5TB library to 700GB library along with old backup jobs, how to do it?
Best answer by jgeorges
View originalHi,
View originalThis should give you what you need:
https://documentation.commvault.com/11.24/expert/9302_moving_mount_path.html
Let me know if you have any questions this doesn’t cover
Hi
I provided a pretty exhaustive response here to the options and some others came in with feedback on their preferences:
Its not exactly directed to you’re question, however covers with a bit of detail on what you’re trying to do.
Cheers,
Jase
