Identify hot/cool/archive usage in Azure easily
  • 30 December 2021
  • 608 views
Badge +1
I hope this is simple to answer for someone.  I looked in the Azure portal but was unable to find what I was looking for.
We’re new to using Azure archive for our secondary copies, and the billing seems higher than expected.  Actual billing is showing about five times higher than estimates.  We’re wondering if some data is in hot or cool rather than archive.  Is there an easy way to identify what is in hot, cool, and archive by a chart or something in the portal?
Best answer by Mike Struening RETIRED 6 January 2022, 16:13
Badge +15
Hi @kevcor
Thanks for the question, I’ll reference a few different resources here for you to check out.
Commvault - Cloud Storage Building Block Guide
Commvault - Planning Archive Storage Tiers
Commvault - Managing Cloud Storage
Commvault - Modifying the Storage Class for an Existing Cloud Library
Note: When the bucket is modified to a new storage class, new data will be stored using the new storage class. Existing data will always remain in the old storage class.
Commvault - Migrating Data Between the Storage Classes in a Cloud Storage Library
Note: To migrate existing data to a new storage class, contact the storage vendor and follow the steps recommended by the specific storage vendor.
New data can be backed up to the changed storage class by modifying the storage class in the library.
Microsoft Azure - Set a blob’s access tier
The section for Upload a blob to the default tier shows a screenshot for Dashboard > Storage accounts > [storage_account] > [container] and will show the access tier for items for you to check.
Individual items within a storage account can reside in different tiers, so there doesn’t seem to be a way or an overview to show this simply, you’ll need to check the details for storage accounts.
I hope that helps!
Thanks have a Happy New Year!
Stuart
Badge +1
I saw that individual items will list their tier, but I was hoping to find a chart or something that broke out tier usage by item count or storage usage.  How are we supposed to keep MS honest on our billing?  Right now we either have items in hot that we don’t want there or we’re not being billed correctly.
@kevcor , have you look at the explorer tool they provide?  I can see that their tier is mentioned, though I don’t know how deep you can explore to see what is where by item (though storage is listed).
https://docs.microsoft.com/en-us/azure/vs-azure-tools-storage-manage-with-storage-explorer?toc=%2Fazure%2Fstorage%2Fblobs%2Ftoc.json&tabs=windows
I admittedly do not have any experience with Microsoft Azure Storage Explorer, though!
