Immutable Backup Images
  • 25 February 2021
  • 2448 views
Badge +1
We currently have a ‘dual-site’ scenario - each with 2 media agents attached to a Dell/EMC ME4084 disk library.  Commvault is configured with a CommCell in each site - with failover enabled.  Backup images are secured in each local site and then a secondary copy replicated to the alternate site.
As I am sure is common - the questions are being raised around immutable backups in this CV environment
I have seen documentation regarding immutability of cloud based backups, and discussions of WORM technology - but am unsure as to what applies to us here with our CommVault / disk library configuration.
V11 SP20
Any input appreciated…..
Best answer by Damian Andre 25 February 2021, 18:19
Badge +13
I believe Amazon Immutable will be available in SP22
https://www.commvault.com/resources/greater-ransomware-protection-with-data-isolation-and-air-gap-technologies
https://documentation.commvault.com/11.22/expert/9251_configuring_worm_storage_mode_on_cloud_storage.html
Badge +15
It seems like that Cloud is not a library destination for you at the moment. So I would suggest reading the papers shared previously but also taking a detailed look at the Authentication, authorization and accounting aka (AAA) framework that will give you a good understanding of what can and has to be done in your environment.
https://www.commvault.com/resources/secure-your-data-your-recovery-and-your-mission
You can absolutely apply WORM to disk/network targets - data will be held until the retention is met. Retention cannot be lowered and jobs cannot be deleted.
https://documentation.commvault.com/commvault/v11_sp20/article?p=13938.htm
Just note the caveats, as it's generally a one-way street (which is the entire point :blush: ).
Also, be sure to check/enable ransomware protection which will help disable tampering with your disk library from malicious applications.
Badge +1
Damian,
Most helpful - exactly what I was looking for !
The Ransomware protection was already enabled on the 4 media agents attached to the disk libraries - but good to point out….
Andy.
Damian,
Andy.
Awesome!
Additionally, there is a great security assessment dashboard for Command Center in FR20 and later as well. It covers other best practices of things you can do to better secure the environment. Here is a quick video on it and here is the documentation. I think it's been improved beyond FR20 but I thought it may be helpful for you.
