Multiple DDB Partitions or Single DDB Partition
  • 23 February 2021
  • 1239 views
Badge +11
Hi Team,
I have a query . If a storage library has 8 mount paths , all configured from different media agents and shared with each other .
Should we create DDB partition on all 8 media agents or only on 1 media agent ?
What will help to increase performance of backup jobs  , DDB is hosted only on 1 media agent or distributed across multiple media agents ? I am thinking that if DDB is hosted only on 1 MA backup job has to look only on 1 MA everytime for duplicate blocks and signatures , if the DDB is distributed wouldn't it make the backup job slower as the backup job will check for duplicate blocks and signatures across multiple configured DDB partitions .
Let me know if my understanding is incorrect ?
Best answer by Prasad Nara 25 February 2021, 01:10
Badge +6
DDB look is same for both 1 partition vs multiple partitions. Lookup of a given signature of a block always happens on one partition based on mod value of it with number of partitions.
You will get better performance and resiliency with multiple partitions spread across multiple MAs. I would suggest to use 4 partition DDB with Horizontal scaling of DDBs feature enabled so that you can distribute partitions from all DDBs across all available MAs.
Userlevel 1
Badge +7
Have a look at sizing guide. Main factor should be backend data size that DDB will handle.
Badge +11
Hi Prasad,
Thanks for the reply. What do you mean by Mod value? How it is determined?
Badge +6
Hi Prasad,
Partition is a subset of DDB. Signatures are routed to appropriate partition using mathematical modulo operation. For a 2 partition DDB, we use the mod of 2 on the signature and possible return values will be either 0 or 1. if 0 then signature goes to partition 1 else partition 2. This way lookup happens on the particular partition.
