Office 365 Backup Storage Calculator
  • November 24, 2021
  • 920 views
Is there a calculator (or formula) to estimate the required backup storage capacity for Office 365 Backups (Exchange Online, OneDrive for Business, SharePoint Online & Teams)?
For “normal” backups (File, VMs, Databases) there is such a calculator (Link), but I haven’t found anything regarding Office 365.
How do others run such capacity calculations for Office 365?
Regards
Chris
Best answer by Scott Reynolds
@ChrisK
This info can all be obtained from the Azure portal page.
admin center, go to the Reports > Usage
There are various reports for usage, sizing, etc which will give you a very close estimate on what total size you are using, it can report on all three of those agents Exchange, SharePoint, Teams, and OneDrive.
I believe there are even advanced reports that will give you activity that might help determine change rate in your environment to assist with incremental sizing if required.
https://docs.microsoft.com/en-us/microsoft-365/admin/activity-reports/activity-reports?view=o365-worldwide
Good question, @ChrisK !
Let me ask around and see if we have anything available (or anything coming around).
I asked around and we don’t have a similar tool, though my collegaues suggested checking what Azure lists per application and start there:
https://www.itproiowa.com/faq-items/check-much-space-used-office-365-onedrive-sharepoint-online/
You might be able to use the calculator anyway as long as you have the other values.
@ChrisK
