Preferred restore location: Recovery data from azure cloud library
  • 24 February 2021
  • 7 replies
  • 82 views
Badge +1
Hi There!
I have Vmware vm backed up on-premises and auxiliary copy to Azure cloud library. When I try recovery a VMs that I supposed already transferred data to azure, I’m able to see bandwidth on firewall ports increase. So I think this scenario report a local data recovery to azure.
I’d like to recovery data that already on azure cloud ( that was transfer by auxiliary copy).
Someone could hep me with this steps?
Best answer by Mike Struening RETIRED 24 February 2021, 16:01
Badge +13
Have you checked the copy precedence of the restore you are running to make sure it’s pointing to the other copy?
https://documentation.commvault.com/commvault/v11_sp20/article?p=58197.htm
@NelsonBalbo , how are you initiating the restore?  Are you browsing the client or browsing jobs on the Aux Copy directly?
You likely have Copy Precedence set to the local copy:
https://documentation.commvault.com/11.22/expert/58197_advanced_restore_options_copy_precedence.html
Badge +1
Thanks @Mike Struening and @Aplynx
@Aplynx I didn’t check the copy precedence of the restore…
@Mike Struening, I’m initiating the restore by browsing vmware client. I will check the copy precedence of the restore…
 I will try and post the results! Thank so much!!!
Great, thanks!
@NelsonBalbo , any luck on the Copy Precedence?
Badge +1
Hi @Mike Struening and @Aplynx,
after apply your recommendation “copy Precedence”, job restore not consume firewall bandwidth!
Thanks for all!!!
SWEET!!
Happy to have helped.  Thanks again for posting on our community.  Looking forward to your continued membership and contributions!
