Which is the better solution considering the Cost, Space, Dedup Parameters, Throughputs for a Primary Copy only?
- Primary Copy : With Daly incremental, Weekly Full, On Azure immutable with Dedup that is a mix of DDB Sealing, Data retains longer than my basic retention of 30 Days. (Aux - Full Backups later go to Azure immutable container)
- Primary Copy : With Daly incremental, Weekly Full On DD - with NO DEDUP, with basic retention of 30 Days. Later have the Full Backups Aux to Azure immutable Cloud.
FYI : My Aux copy of Full backups will stay Azure immutable, there is no change in this concept.
Just want to make sure having a DD for the primary copy daily backups would be beneficial considering the above parameters.
Can you please help me decide
