Restore from offsite private cloud with no direct connection
  • September 6, 2021
  • 102 views
ApK
Apprentice
Hi All.
I have a question regarding restore of data which resides on a offsite private cloud where clients have no access.
Setup is:
On prem Client network with servers in backup.
→ Firewall in between with port open for backup traffic.
On prem Backup network with MediaAgents and storage.
→ Firewall in between with port open for aux copy data.
MediaAgents with offsite private cloud storage containing Aux copies of client data.
Clients do not have access to the offsite MediaAgents/copy, so my question is, how do I make a restore of data from the offsite cloud, when the On prem clients and the offsite MediaAgents cannot talk to each other directly? Is it possible to route restore traffic via the on prem MediaAgents acting as a proxy some how? Would the network gateway via outgoing routes be the solution?
Any suggestion would be appreciated.
Thanks for helping.
-Anders
Best answer by Alireza B
Short answer is yes you can use your on prem MA as a proxy. Ideally this MA will have 2 NICs for talking to Clients and offsite MA.
Please see this:
https://documentation.commvault.com/m/commvault/v11/article?p=features/firewall/dmz_proxy.htm
Alireza B
Forum|alt.badge.img+8
  • September 6, 2021
Please see this:
ApK
Apprentice
  • September 16, 2021
Thanks Alireza, worked perfectly.
Regards
-Anders
