I have a question regarding magnetic disk library setup and how will it affect restores.
So what is being in the thoughts:
- Library has for example 4 media agents assigned to it;
- Each media agent would have own mount path provided from SAN;
- We would then share mount paths between media agents (exportfs (NFS..))
- Local to media agent mount path would have Read/Write access and other media agents who have that mount path as a shared one would have Read access
- Transport Type would be Regular
- Mount paths would have spill and fill for load balancing
With this setup a question came: what will happen if backup_1 was backed up into media_agent_1 out of 4 media agents used in that library, and this media agent is offline - can we still restore data from backup_1 with other 3 remaining media agents? At this point looks like a no - because mount paths to which backup_1 has been done is offline, so how can other media agents in the library be used for a restore?
Can this work? If not - can you suggest something from your view?
Best answer by Jordan
