Automatic virtual machine backups tests
  • 25 November 2021
  • 22 views
Userlevel 2
Badge +10
I will be very appreciate for help.
I would like to run automatic virtual machine backups tests. Could I ask for an instruction where this functionality will be configured?
Thank you in advance!
Badge +6
Hi @kszaf
Can you explain what you are trying to achieve please?
What would be the difference between a Production & Test?
Under the same Hypervisor Client, you can create a new Test Backupset, configure Default or more Subclients and finally configure the schedule(s).
Let us know
Sebastien Merluzzi
Userlevel 2
Badge +10
Hi @Sebastien Merluzzi thanks for your time and help!
By tests of copies, I mean testing the correctness of performed backups. For example: I would like to run a backup restore to the test environment once a month to check if the backup works (virtual machine backups). I would like to do this automatically. If there is such a functionality in the program that it periodically restores the backup, starts it to check it, and then deletes it, please let me know where it is done.
Userlevel 5
Badge +12
Hi @kszaf ,
We do have “Application Validation” in the Command Center which can be used to validate streaming backups of VMware guest virtual machines, including VMs that run applications.
See a link to the feature’s documentation here:
https://documentation.commvault.com/11.24/essential/111292_application_validation_for_vmware_vms.html
Michael
