Commvault infrastructure antivirus exclusion
  • 8 April 2021
  • 4516 views
Badge +14
Hello, Is there any detailed documentation on how to put antivirus exclusion for commvault 11.22.13 for :
We use Symantec endpoint protection
  • Commserves
  • Media agent on Windows
  • Media agent on Linux
Best answer by MichaelCapon 8 April 2021, 11:12
Badge +14
Hi @Bloopa,
I usually recommend the below to customers:
Exclusions for Windows CS/MA: Recommended Antivirus Exclusions for Windows (commvault.com)
Exclusions for UNIX: Recommended Antivirus Exclusions for UNIX and Macintosh (commvault.com)
No environment is 100% the same so its worth checking things like Mount Paths, IndexCache, DDB Locations on your machines and explicitly exclude those from AV software.
Michael
