How to get commvault version compatibility guide for ida agents?
  • 14 September 2021
  • 680 views
Badge +5
Best answer by Stuart Painter 14 September 2021, 15:47
Badge +15
Hi @Mansoor
There is no one page that shows version compatibility for all agents.
Instead, we have pages categorised for each agent in Documentation.
For example, if you want to know the version compatibility for VMware, you would go to:
Essential > Virtualization and Cloud > VMware > System Requirements
for SQL Server:
Essential > Databases > SQL Server > Getting Started > System Requirements
Unix File System:
Essential > File Servers > Unix, Windows and Macintosh File Servers > Getting Started > System Requirements
There are similar pages with specific requirements for each agent, under each Feature Release.
Stuart
