System State shows Zero Bytes while on restore selection
  • 13 April 2021
  • 21 views
Badge
I believe that this is not an issue but someone asked so i wanted to clarify. When you to restore files from a server, the System State show Zero Bytes. My assumption is that the area is more of a place holder and the size of the system state is included with the C: drive backup size that shows. Am I correct?
Best answer by Alireza B 15 April 2021, 00:50
I think system keeps the System State total size in Index. What’s the service pack on the Media agent, Client and CS?
Badge +4
I believe this is correct. It looks like you are able to expand the system state, see the components and services and then restore them out of place.
Badge +4
