Hello Commvault community,
I come to you to consult if it is possible to have the role of VSA proxy and IBM i File System proxy on the same server, to backup VMware virtual machines and AS400.
Thanks for your attention and support!
Hi Andres,
VSA proxy requirements are listed here. IBM is not a supported OS if we are talking about VMWare:
https://documentation.commvault.com/v11/essential/107803_vmware_system_requirements.html
Hi Alireza,
Thank you very much for your reply. I mean more exactly if a server can have these two roles installed at the same time:
Access node IBM i File System
And VSA (with FREL)
