IBM i File system Proxy and VSA Proxy on same server
  • January 12, 2023
  • 170 views
AndresLeo
Novice
Hello Commvault community,
I come to you to consult if it is possible to have the role of VSA proxy and IBM i File System proxy on the same server, to backup VMware virtual machines and AS400.
Thanks for your attention and support!
Alireza B
Forum|alt.badge.img+8
  • January 13, 2023
Hi Andres,
VSA proxy requirements are listed here. IBM is not a supported OS if we are talking about VMWare:
https://documentation.commvault.com/v11/essential/107803_vmware_system_requirements.html
AndresLeo
Novice
  • January 13, 2023
Hi Alireza,
Thank you very much for your reply. I mean more exactly if a server can have these two roles installed at the same time:
Access node IBM i File System
https://documentation.commvault.com/hitachivantara/v11/expert/16163_getting_started_with_ibm_i_file_system_agent.html
And VSA (with FREL)
