Can someone confirm from Commvault that in the case where DASH fulls are ran along with incrementals and the tape copy is synchronous, does the aux copy job (from disk to tape) essentially make it possible to restore any VM to the point it was last backed up, regardless of whether a full or inc happened last? Meaning it does not have to stitch together all sorts of incs. but rather takes the guesswork out of it so similar to restoring from disk, whenever you tell it to restore “to” those incremental jobs seen in the tape copy are essentially “fulls”? This is what I see when browsing media and comparing full jobs to inc’s - same exact file sizes and content for each VM. I didn’t think the intelligence was in there but at the rate the tapes are being consumed, it does indeed seem like every inc is basically converted to a full before writing to tape.
Is that observation correct? If so, that is perfect.
thanks
Best answer by Scott Moseman
