Hi Team,
in the CVLT documentation we found the following limitation:
For streaming backups and backup copies, if the access node used for backups and restores is running on an Amazon EC2 instance, the access node must be available in the same user account as the instance being backed up or restored. This requirement does not apply to IntelliSnap backups
Does it mean that if we backup Oracle/Hana inside an EC2 with CVLT Agent we must place the AN in the same AWS account as Oracle EC2 ?
While in the following link we see indicated that :
Hypervisors can use AWS service account resources for the following operations:
Streaming backup
Etc
Using Resources from a Service Account (commvault.com)
Can you please confirm if AccNode can definitely be deployed solely into a Service Account w/o limitations ?
Many Thanks.
Francesco
Best answer by BackupDev
