Erroce code 82:127
  • June 23, 2023
  • 27 replies
  • 1217 views
Show first post
Carmine Bollettino
Apprentice
@Carmine Bollettino ,
I will ask the engineer to add a key the Media Agents and run a new Backup again:
Hi, where should this key be inserted?
In the registry and in what position?
I need more information.
Is it solved?
Thank you
Carmine
To me it looks like the client DDB cache option is enabled. Can you check and disable?
https://documentation.commvault.com/2022e/expert/12451_modifying_deduplication_properties_for_client.html
Can you disable Source-side disk cache and try?
