How to backup tanzu environment?
  • 2 December 2021
  • 932 views
Badge
is there any best practice for backing up tanzu environment ?
thank you.
Best answer by Stuart Painter 2 December 2021, 13:13
Badge +15
Hi @Ravit
Thanks for the question!
https://tanzu.vmware.com/tanzu
We have some Kubernetes documentation, please take a look at:
Supported Configurations for Kubernetes
Kubernetes Distributions
The Commvault software supports all CNCF-certified Kubernetes distributions and Kubernetes revision versions 1.21.x-1.14.x.
The following distributions are validated by Commvault:
Stuart
