How to backup tanzu environment?
  • December 2, 2021
  • 1285 views
is there any best practice for backing up tanzu environment ?
thank you.
Best answer by Stuart Painter
Hi @Ravit
Thanks for the question!
https://tanzu.vmware.com/tanzu
We have some Kubernetes documentation, please take a look at:
Supported Configurations for Kubernetes
Kubernetes Distributions
The Commvault software supports all CNCF-certified Kubernetes distributions and Kubernetes revision versions 1.21.x-1.14.x.
The following distributions are validated by Commvault:
Stuart
Hi @Ravit
Stuart
