Incorrect transport mode selected
  • 14 March 2024
  • 23 views
Badge
Hi Team,
Backup failing with error “Error opening the disks for virtual machine [up0022alli_UCS_Central]. Verify that the correct transport mode is selected.”
Initially Transport mode was: NBD. It will fail sometime, but will get completed using the same transport mode.
Later changed it to Auto: Again its using NBD. Similarly sometimes failing sometimes completing.
Badge +14
HI @Suryavamsi ,
Can you check vsbkp.log on VSA and see why it fails?
Or you can log a case with Support and we will check.
Sebastien
