Nutanix AHV 5.20
  • May 28, 2021
  • 7 replies
  • 176 views
Hi all,
Does anyone have any inside info as to whether AHV version 5.20 will be supported any time soon?
Our customer really needs to upgrade to take advantage of the new Nutanix features.
Thanks in anticipation.
Best answer by Mike Struening
@Shane , just heard from dev a few minutes ago.  They are currently working on 5.19, and see no issues with 5.20.  They advised to go ahead and use it (though if you encounter issues, raise a support case to be safe).
  • May 28, 2021
@Shane Working on getting you an answer!
  • Certified Expert
  • May 28, 2021
Thanks, Dan
  • Certified Expert
  • June 2, 2021
Brilliant, thanks Mike!
My pleasure, @Shane !!
  • Certified Expert
  • June 4, 2021
Sorry @Mike Struening, perhaps I should have asked...
Is dev’s answer based on any particular SP? The customer is currently on 11.20.46.
  • June 4, 2021
It’ll be supported from 11.20 on and support for 5.20 will likely show up in BOL within the next 45 days or so. Just working through upgrades/backlog and the formal cert process with Nutanix.
