Rest API - GET VM (lists info of all VMs) - how to get complete record info for a particular VM?
  • October 17, 2022
  • 12 replies
  • 817 views
Forum|alt.badge.img+8
https://documentation.commvault.com/v11/essential/125353_rest_api_get_virtual_machines.html
GET <webservice>/VM operation give us the  list of virtual machines
it gives almost all the info about the VM, like latest backupjobid, vmsize, the virtualization client info, subclientid, clientid etc.
Instead of listing all VMs’ i want this info for a specific VM, how shall i fiilter out the info for a VM in this API operation.
2 methods that i tried are, but this isn’t giving me complete info
GET <webservice>/VM?Search=vmStatusInfoList.client.clientName%3Acontains%3Axpath:{/workflow/inputs/source_vm}&
GET <webservice>/VM?Search=vmStatusInfoList.vsaSubClientEntity.subclientName%3Acontains%3Axpath:{/workflow/inputs/source_vm}&
but I’m not getting the complete info of that VM, i would like to retrieve the whole record info for a specific VM.
Example:
Sample response of Get VM
"totalRecords":5,"pageNo":0,"errorMessage":"","errorCode":0,"pageSize":100,"vmStatusInfoList":[
"vmHost":"",
"bkpStartTime":1665719167,
"type":9,"vmStatus":1,
"slaStatus":1,
"vmUsedSpace":6442642704,
"isFSAgentBackedUp":true,
"subclientId":1234,
"bkpEndTime":1665719336,
"vmFailureReasonForWarning":"",
"name":"vmtest1",
"storagepolicyName":"VM_IntelliSnap_StoragePolicy",
"slaCategory":1,
"vmGuestSpace":6442642704,
"latestBackupTimeCatalogedSuccessfully":0,
"isIndexingV2":true,
"vmBackupJob":1234567,
"strOSName":"windows-server-2012-r2-dc",
"isDeleted":false,"vendor":16,
"osType":1,
"applicationSize":6442642704,
"vmSize":6442642704,
"slaCategoryDescription":"Protected",
"vmAgent":"cvltproxy",
"retireClientPhase":0,
"isContentIndexded":false,
"isBackupAllowed":true,
"vmHardwareVer":"",
"strGUID":"1234567891234567891",
"subclientName":"vmtest1_2_daily",
"vsaNextBackupSubClientEntity":{"backupsetId":4321,"subclientId":1234,"subclientName":"vmtest1_2_daily","flags":{}
},"instanceEntity":{
"instanceId":1677
},"commCell":{
"_type_":1,"commCellName":"cvltserver","csGUID":"test-1234-TEST-1234"
},"proxyClient":{
"clientId":9123,"clientName":"cvltproxy"
},"plan":{
},"vsaSubClientEntity":{
},"client":{
"clientId":2345,"clientName":"vmtest1","displayName":"vmtest1","flags":{
"include":true
},"pseudoClient":{
"clientId":5678,"clientName":"IntelliSnap_VM","flags":{
"disabled":false
},"lastBackupJobInfo":{
"jobID":1234567,"commCellID":9,"failureReasonMessageEnglish":"","status":1,"startTime":{
"time":1665719167
},"endTime":{
"time":1665719445
....similar other records for remaining VM’s
Best answer by christopherlecky
The simplest way to achieve that is to charge your http request to return XML rather than JSON
and then use an xpath query.
You could prototype it using an online xpath editor like this one https://xmlgrid.net/xpath.html
It’s basically a query against the xml output that you could use to filter for what you want.
It would be much easier if there was a jsonpath activity built into the workflow system
Onno van den Berg
Forum|alt.badge.img+24
@alligator what is the use-case? if you are writing code yourself then you could very easily filter it out yourself, right? in case you are running a recent version it might be worth looking at the newer API implementations, but retrieving specific VM information always requires a lookup for the unique identifier to be able to pull detailed information, related to the specific VM, from the API.
  • October 17, 2022
@Onno van den Berg so you mean to say, first i must do a GET VM, from the output i must extract the VMUUID and then perform a GET/VirtualMachines/{vmUUID}
Onno van den Berg
@alligator correct but in case the GET VM call already extract the required information that you can filter it out from there yourself.
  • October 17, 2022
 @Onno van den Berg thank you
yes i was specifically looking to fetch the subclientID from the record for the given client.
So i will be giving the vm name as the input and i want the subclientid to be fetched, so in next step i can do a “DoBrowse” using that
So was looking for an easy way to achieve that.. :) 😬
christopherlecky
Challenger
Forum|alt.badge.img+16
christopherlecky
Challenger
Alternatively you can import the JSON input into script convert it into a Java/JS object and extract your data that way.
  • October 17, 2022
@Onno van den Berg @christopherlecky
Thanks alot for the answers.
Xpathquery seems to be the easiest way to me
but i’m finding it a bit difficult to find the query . it works when the value is a number
//vmStatusInfoList/client[clientId=4]/clientName
This way its giving me the output , but i need the info the other way, i would pass the vm name, i need the clientID/subclientID etc.
//vmStatusInfoList/client[clientName='ty-vm']/clientId
Also i couldn’t find any sample for XPathQuery activity in other standard built-in workflow.
Is there any that you know which i can refer to
christopherlecky
Challenger
The reason I didn’t just give the xpath string is because the json output you entered was malformed,
Can you post the JSON/XML output in it’s entirety and I’ll give you xpath string you need to get you what you want.
Note: I am pressed for time so I may not get back to this today.
  • October 17, 2022
here is a sample xml, so i only have the vm name,
from this GET VM xml output, i want to find the subclientId of the given vm
name
vm client info (client/(s) added in the subclient)
  • October 17, 2022
thanks alot in advance
  • October 18, 2022
I think i found the XPath Query to get the subclientId for the specific vm
christopherlecky
Challenger
Awesome, does it work?
I was hoping you would list the xml in a code snippet rather than as an attachment, I don’t really have the time to download import and modify the xml.
I just pop in from time to time when I get stuck on something.
