Script/XML to delete VM from Subclient
  • 20 November 2023
  • 8 replies
  • 38 views
Badge +4
I am looking for a command wherein i can just give VM Name and delete that VM from Subclient which has many VMs in it. Is there a command or an XML using which this can be achieved. Need to use it for decommission process.
Badge +13
Hi @Rahul Nair ,
Can you check this:
https://documentation.commvault.com/2023e/essential/101876_remove_cvvirtualmachine.html
Sebastien
Badge +4
Yeah i went through this but I am not looking for a powershell module. Anything through XML or a qcommand. I will have to first identify the VCenter name and subclient name through VMName and then use those in the script so looks to be a bit tedious. Any help would be appreciated.
Badge +13
We don’t have a qcommand.
Badge +4
okay, so the only option to use is Powershell module?
Badge +13
That’s right.
Badge +13
This one:
https://documentation.commvault.com/2023e/expert/32427_deleting_virtual_machine_from_subclient_vmware_command_line.html
Is this what you are looking for?
Badge +4
Hi Sebastian,
Yes thats right i was looking for this. thanks a lot for the help.
Badge +13
ok, great, please mark it as solved.
