Unable to restore AHV vm from Command Center
  • May 31, 2024 2:03 PM UTC
  • 47 views
I am unable of restoring a full virtual machine from Nutanix AHV using Command Center.
Restoring a Full VM from vCenter is working however.
Restoring the VM from AHV using the Commcell Console is also working.
Problem was noticed in version 11.34.20. I upgraded today to version 11.34.27. That is no solution.
Anyone any idea how to solve this?
Bart
Hello Donders,
If you have an example of it working before your upgrade and then it not working after i recommend raising a support ticket and providing all those logs. If there is a bug its best to get it to Dev ASAP to address. Please report back on this thread if it was fixed or addressed with Dev’s help or if support fixed it for you.
Kind regards
Albert Williams
