I’m deploying a 2 node grid pair (local storage shared using dataserver IP), these servers also have the virtual server agent deployed and are both defined in the pseudo client.
When I take node 1 offline (which is the top node in the VSA Proxy order) simulate a failure the VSA backups go to a waiting state with “14:201” Index from previous job was not found on MediaAgent, When I take node 2 offline the MediaAgent resources failover as you’d expect
The current VMware pseudo client is V1 indexing, if I create a new pseudo client and upgrade it to V2 indexing will this resolve the issue and allow jobs to continue to run if the primary VSA proxy/MediaAgent is offline?
Also, I know that you need to disable the existing pseudo client, create a new one, run the workflows to update / import configs, but can I get away with just creating a new pseudo client and running the upgrade to v2 workflow (i’ll happily re-create the configuration) and leaving the old pseudo client running the legacy environment until I cut it over?
Best answer by NunoS
