Bocada Integration
  • 27 January 2023
  • 38 views
Badge +8
Is there any documentation available to integrate Bocada into Commvault. This product is used for monitoring.
https://www.bocada.com/supported-applications/commvault-montoring-reporting/
It looks like the requirement is for a read-only user directly in SQL and not via API authentication.
Is creating an account within SQL allowed? Or is there an alternative method to achieve this?
Thanks.
Ignes
Best answer by Sebastien Merluzzi 27 January 2023, 11:51
Badge +14
Hi @Iggy ,
I see you have logged a case already.
I had a quick look and yes you can login using SA account  to create other accounts or use it for reporting.
Sebastien
Badge +8
Hi @Sebastien Merluzzi ,
Thank for the info.
I don’t have the sa credentials. Will Support assist with this?
Cheers.
Badge +14
Yes, we can use our Account and then change the SA password.
