Bocada Integration
  • January 27, 2023
  • 93 views
Is there any documentation available to integrate Bocada into Commvault. This product is used for monitoring.
https://www.bocada.com/supported-applications/commvault-montoring-reporting/
It looks like the requirement is for a read-only user directly in SQL and not via API authentication.
Is creating an account within SQL allowed? Or is there an alternative method to achieve this?
Thanks.
Ignes
Best answer by Sebastien Merluzzi
Yes, we can use our Account and then change the SA password.
Hi @Iggy ,
I see you have logged a case already.
I had a quick look and yes you can login using SA account  to create other accounts or use it for reporting.
Sebastien
  • January 27, 2023
Hi @Sebastien Merluzzi ,
Thank for the info.
I don’t have the sa credentials. Will Support assist with this?
Cheers.
