Restore directly to Synology NAS
  • 11 April 2023
  • 8 replies
  • 256 views
Userlevel 2
Badge +13
Hello community, a quick question!
Is it possible to proceed a restore directly to a Synology NAS ?
A guest file restore for example, from a VM → out-off-place restore directly to a NAS device!
From Command Center, for out-off-place restore, I can see only MediaAgent, and other VM’s as a destination and not a NAS device.
Badge +8
Have you tried it as a UNC path from the Restore options?
Userlevel 2
Badge +13
Hello @Hyder
Thanks for your reply!
You mean to add/map the NAS path in a VM and restore it there?
I cannot see a UNC path option in Restore options, only destination clients:
Badge +14
Hi @Nikos.Kyrm ,
That’s right the best way would be to map a network drive.
Sebastien
Userlevel 2
Badge +13
OK, so @Hyder ,
There is no alternative way, maybe through an agent installation in Synology ?
Badge +8
There’s no agent you can put directly on the Synology, if it a shot like @Sebastien Merluzzi said also, let us know how you make out
Userlevel 2
Badge +13
Hi @Nikos.Kyrm ,
Sebastien
Hello again,
I mapped a NAS path to MediaAgent, but when browse the MediaAgent, Im not able to see the network map drive letter in order to proceed with the restore in this path!
Badge +14
Hi @Nikos.Kyrm ,
Can you copy/paste the path, i.e Z:\Restore?
Sebastien
Userlevel 2
Badge +13
Hi @Nikos.Kyrm ,
Sebastien
Hey @Sebastien Merluzzi !
Your suggestion was correct to edit the path.
For Linux NAS as destination, the user / credential format must be like below:
