SQL Server Installer is not present on current DVD
  • 11 May 2021
  • 1093 views
Badge +14
hello,
I am trying to install a test commserve
I have this error message
I verified the installer and it is the same that I use to install media agents, client etc …
Do you know what could be the issue ?
Best answer by Shane S 11 May 2021, 15:32
Userlevel 1
Badge +2
@Bloopa ,
You may need to create a new installation package and ensure that “Include MS SQL Server” option/checkbox is checked in the Download Manager wizard in order to bundle the required Microsoft SQL Server software for the Commserve installation
See step #6 in the below article:
https://documentation.commvault.com/commvault/v11_sp20/article?p=2689.htm
Badge +14
Sorry the package I have downlaoded doesn’t contain the MSSQL package in the Third Party sub folder
This is why there is an error.
Userlevel 1
Badge +2
Exactly!  Therefore, you need to create a new media package with MS SQL included.  Please refer to my previous message for instructions
