Something is not correct in the documentation !
Starting a Node After a Reboot have exactly all the same steps as the Starting a Node Manually ??
Thank you
View originalSomething is not correct in the documentation !
Thank you
View originalHey,
I looked at them both side by side….the only difference I can see is that for the Manual version, you have to start the services yourself, the other (nearly identical) write up omits two steps (forgive the formatting) which kind of makes sense(?):
4.Exit the admin user mode.
# exit
# commvault start
If the only difference is Exit and Commvault start !! They should have two ways to restart services (manual and automatic) after a reboot !
The longest part is
# su - admin
# export HV_PUBKEY=1
# /opt/hedvig/bin/hv_deploy --show_all_clusters
This will display the cluster name, as shown in the following sample output:
Cluster name: HV13102021054000 - owner: unowned - version: v-4.5.0.0.2.3597.00320e0ba9:06aca75bc4db06170a13ef14cbfe8446
Use the cluster name to start the node using the following command:
# /opt/hedvig/bin/hv_deploy --start_node <fqdn hostname> --cluster_name <Clustername>
