Additional settings registered
But it's been deleted
Do you know why?
View originalAdditional settings registered
Do you know why?
View originalDid you notice this after certain changes/updates?
Are there specific or random additional settings involved?
I would check to see if you have that same setting disabled at another level. to verify where the settings are applied you can use this report. make sure there are not two or more client groups where one group has it enabled and the other has it disabled.
report - https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/11243
Are you adding these settings in the Additional Settings section in the CommCell console or are you manually adding them to the registry?
version is V11 SP13
SP13 is almost 4 years behind the current maintenance release. Do you have plans to upgrade anytime soon? Also can you please answer the following question:
