Additional settings are automatically deleted
  • July 19, 2022
  • 80 views
Additional settings registered
But it's been deleted
Do you know why?
When did you notice this? What version are you running?
Jos Meijer
Forum|alt.badge.img+21
  • Community All Star
  • July 19, 2022
Did you notice this after certain changes/updates?
Are there specific or random additional settings involved?
Onno van den Berg
Forum|alt.badge.img+24
  • July 19, 2022
I would check to see if you have that same setting disabled at another level. to verify where the settings are applied you can use this report. make sure there are not two or more client groups where one group has it enabled and the other has it disabled.
report - https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/11243
Forum|alt.badge.img+18
  • July 19, 2022
Are you adding these settings in the Additional Settings section in the CommCell console or are you manually adding them to the registry?
  • July 20, 2022
version is V11 SP13
  • July 20, 2022
SP13 is almost 4 years behind the current maintenance release.  Do you have plans to upgrade anytime soon?  Also can you please answer the following question:
