Auto Detect VM Owner
  • March 28, 2023
  • 249 views
Forum|alt.badge.img+9
Is there a way to change this sub-client attribute via REST API - ‘Auto Detect VM Owner’ ?
We haven’t found and supportive documentation for it.
Best answer by Damian Andre
Hi @TNO,
Here is the details on this feature: https://documentation.commvault.com/2022e/essential/114157_vm_owner_identification_for_vmware_or_vmware_cloud_director_01.html
You can manually assign owners in the UI via this method:
https://documentation.commvault.com/2022e/expert/8214_assigning_permissions_to_owners_at_commcell_level.html
I think this is the correct API from https://api.commvault.com/
http://WebConsoleHostName/webconsole/api/Security
curl --location 'http://WebConsoleHostName/webconsole/api/Security' \
--header 'Authtoken: QSDK token would be auto set after POST Login is called.' \
--header 'Accept: application/json' \
--header 'Content-Type: application/xml' \
--data '<App_UpdateSecurityAssociationRequest>
<entityAssociated>
<entity clientId="5" _type_="3" />
</entityAssociated>
<securityAssociations associationsOperationType="1">
<associations>
<userOrGroup userId="0" _type_="13" userName="testadmin" />
<properties>
<role _type_="120" roleId="20" roleName="VM End User" />
</properties>
</associations>
<ownerAssociations ownersOperationType="1">
<categoryPermission categoriesPermissionOperationType="1" />
</ownerAssociations>
</securityAssociations>
</App_UpdateSecurityAssociationRequest>'
  • April 5, 2023
Hi @TNO,
<entityAssociated>
</entityAssociated>
<associations>
<properties>
</properties>
</associations>
  • April 1, 2024
Raising this topic again,
Is there any way (API, Command line) to modify the setting below ,
