Automatic Groups using ClientName regex?
  • July 23, 2024
  • 87 views
christopherlecky
Explorer
Forum|alt.badge.img+21
Pretty Straight forward,  is there a way to create a smart group whose members are identified by a naming convention using regex?
Best answer by Erase4ndReuseMedia
Using “Preview” takes away some of the pain when testing rule groups, but I do agree that proper regex, or at minimum a consistent implementation of wildcard logic across the platform, would be better.
You could raise a CMR for it. I suspect you’d be waiting a while for it though.
christopherlecky
Explorer
Bump.
I know this one is a reach but it would be really nice.
some alternative to achieve the same thing would be awesome.
Erase4ndReuseMedia
RegEx support would be nice.
Can you just use multiple rules to achieve the same thing?
Match: All
Client Name > Starts With: SRV
Client Name > Contains: PROD
Client Name > Does Not Contain: PREPROD
Client Name > Ends With: [0-5][0-9][0-9]
christopherlecky
Explorer
I would be really convoluted and hard to test, but I see your point.
A regex would be much easier to test for consistency.
The problem is that it's not entirely clear what wildcards are supported for example “?” does not seem to be supported which would make it a lot easier.
Erase4ndReuseMedia
christopherlecky
Explorer
Thanks. I think it’ll do that.
