Aux copy total data to copy
  • April 26, 2021
  • 7 replies
  • 593 views
when I look at the aux copy job status it reflects total data to process as 14.49 TB however when I right click on the storage policy and select Media Not copied the total amount of data is less then 300GB...does that mean the deduplicated data to aux copy is only 300 GB?
Also, as the Aux copy utilizes a DDB at the secondary location the data copied would be less than 300GB?
Best answer by Sean Crifasi
Hi @Theseeker,
The “Data to be copied” in the aux copy summary is the application size of the data
https://documentation.commvault.com/commvault/v11/article?p=13857.htm#o13858
Sean Crifasi
  • April 27, 2021
Hi @Theseeker,
  • April 27, 2021
thanks for that...now it appears that the original aux copy completed with errors; the next aux copy would it automatically copy the data which failed to copy on the original one or would I have to rerun the original aux copy?
Sean Crifasi
It will automatically copy any Jobs that are 'partially copied' or failed to copy on each subsequent attempt. Can you share the error here?
  • April 27, 2021
  04/27 12:33:53 5082301 stat- ID [Media Read Speed], Job Id [5082301], Bytes [56400], Time [0.000260] Sec(s), Average Speed [206.856087] MB/Sec
360   1e30  04/27 12:33:53 5082301 stat- ID [Next chunk recv times], Job Id [5082301], Samples [2], Time [0.201927] Sec(s), Average [0.100963] Sec/Sample
360   1e30  04/27 12:33:53 5082301 stat- ID [Media Open Times], Job Id [5082301], Samples [1], Time [2.312442] Sec(s), Average [2.312442] Sec/Sample
360   1e30  04/27 12:33:53 5082301 stat- ID [PL Alloc Times], Job Id [5082301], Samples [1], Time [0.000008] Sec(s), Average [0.000008] Sec/Sample
360   1e30  04/27 12:33:53 5082301 [Reader_558] Destorying JobRepl Thread Args
360   1e30  04/27 12:33:53 5082301 [Reader_558] Destorying shared members.
360   1e30  04/27 12:33:53 5082301 [Reader_558] Destorying reader specifics
360   f0c   04/27 12:34:20 5082301 [JobCtrl] Asking for [5] additional reservation resources.
360   f0c   04/27 12:34:20 5082301 JM Client  Request to allocate additiona streams [5], noRunningStreams[TRUE]
360   f0c   04/27 12:34:20 5082301 JM Client  CVJobClient::allocateGenericResource(), The resource request identifier is [Global\5082301_360_1619493069_WAIT$Global\5082301_360_1619500432_SHM]
360   f0c   04/27 12:34:21 5082301 JM Client  CVJobClient::allocateGenericResource() - The resource allocation request for job returned ErrorCode[6], ErrorMessage[]
360   f0c   04/27 12:34:21 5082301 [JobCtrl] return value from Allocate Request: [6]..
360   f0c   04/27 12:34:21 5082301 [Coordinator] Reservation Status: JOB COMPLETED WITH PARTIAL SUCCESS
Sean Crifasi
Hi @Theseeker
Apologies for the delay, I am checking this and will get back to you soon.
Sean Crifasi
I checked on this issue with our Media Management team,
Your subsequent aux copy attempt will retry any data that wasn’t processed, if you continue to see this issue I would recommend having an incident created.
If you do create an incident for this can you please share that incident number here or message me privately with the details if you prefer.
  • April 27, 2021
thanks I looked at it this morning and aux copy completed fine and all the jobs were copied across thanks for your help
