Just a quick question on the Bonded Topology for HyperScale X Reference Architecture.
I can see from the BOL that the Storage Pool IP Address should be resolvable to the CommServe server !! Is this a new setting ? I have seen HSX config’s where the storage pool ip address is on a 192.168 range and the CommServe on a 10.10 range with no second nic for a 192.168 range.
Hello @atitagain
This is a mistake in our documentation and we will get it reviewed and corrected. The formatting should be different..
It is saying the Asterisks are required and that each node should be resolvable to the CommServe, rathe than, Everything with an Asterisk should be resolvable to the CommServe.
Thank you,
Collin
