Creating Secondary Copies for Plans, via CommCell Console
  • 23 April 2024
  • 39 views
Userlevel 2
Badge +6
Are there any issues with creating a Secondary Copy for a Plan via the CommCell Console, with the intent of promoting that copy to Primary?
For whatever reason, the Plan isn’t correctly listed within Command Center, and as such I am concerned about causing further issues if attempting the change via Command Center.
Plans are terrible.
Userlevel 1
Badge +5
Hi @Erase4ndReuseMedia ,
If the plan is created in the Commcell console, it should get updated on the Command center as well and that should not cause any issues.
I would suggest you to create a support ticket to review if there is any sync issues with Commcell console and Command Center.
Userlevel 2
Badge +6
Thank you @GnanaPrakasam
Just a follow up question - I don’t see an option within Command Center to make the new Copy a Primary Copy. Is there an issue, or is this just more missing functionality?
Userlevel 1
Badge +5
Currently the feature is not available in Command Center. However, there is a roadmap to add that feature in the Command Center and it will published in the Documentation once it is added.
