CV alerts sent to MS Teams via webhook
  • 28 April 2022
  • 9 replies
  • 619 views
Badge +1
hi, i want to use a webhook for MS Teams to send our CV alterts directly to a dedicated MS Teams channels. The configuration seems easy. Within commandcenter i added the webhook url provided by MS Teams.
Under Monitoring alerts i defined some “standard” definitions like:
Backup Job suceeded to be sent to the webhook.
No adaptions within the template were made.
But in the webhook configuration it always shows me: Webhook offline (date)
Has someone managed already a webhook integration with MS Teams and may share his insights, what changes to the standard configuration is necessary.
thanks
Best answer by Mrityunjay Upadhyay 29 April 2022, 09:32
Userlevel 5
Badge +16
I have nothing to add except…
Teams… ick.
Badge +1
Teams… ick.
cheapest and fastest push notification for mobile devices ...
Userlevel 5
Badge +16
No argument there.
@BernhardSt , while we wait to see if anyone in the community can advise, I’m going to see if we have anyone internally.
I have an answer!
on 24 --- if MOngoDB deployment is standalone server then use FS agent --- https://documentation.commvault.com/11.24/expert/43131_performing_full_backup_of_standalone_mongodb_deployment.html
Expert View
on 24 --- if MOngoDB deplpyment is a replica set or a sharded cluster then use the MongoDB agent https://documentation.commvault.com/11.24/expert/99408_performing_full_backup_of_replica_set_or_sharded_cluster_deployment.html
Expert View
Badge +1
@Mike Struening hi mike. thanks for your answer. but i think the links dont fit to my question. thanks
Userlevel 1
Badge +3
The template should follow microsoft teams format as mentioned in this doc.
https://docs.microsoft.com/en-us/microsoftteams/platform/webhooks-and-connectors/how-to/connectors-using?tabs=cURL
A sample is pasted below. please create new connector and paste following format in template, trigger alert and verify in teams.
  "summary": "<ALERT CATEGORY - ALERT TYPE>",
  "themeColor": "0078D7",
  "title": "<ALERT NAME>",
  "sections": [
      "facts": [
          "name": "Detected Criteria",
          "value": "<DETECTED CRITERIA>"
          "name": "Detected Time",
          "value": "<TIME>"
          "name": "CommCell",
          "value": "<COMMCELL NAME>"
          "name": "User",
          "value": "<USER NAME>"
          "name": "Job ID",
          "value": "<JOB ID>"
          "name": "Status",
          "value": "<STATUS>"
          "name": "Client",
          "value": "<CLIENT DISPLAY NAME>"
          "name": "Agent Type",
          "value": "<AGENT TYPE NAME>"
          "name": "Instance",
          "value": "<INSTANCE NAME>"
          "name": "Backup Set",
          "value": "<BACKUPSET NAME>"
          "name": "Subclient",
          "value": "<SUBCLIENT NAME>"
          "name": "Start Time",
          "value": "<START TIME>"
      "text": "<ALERT CATEGORY - ALERT TYPE>"
Badge +1
hi thank you. now its working!! great. i am happy now :)
Userlevel 5
Badge +16
Just wanted to circle back on this.
Man this is pretty cool.
