When using the CV Failover setting sCSINTERFACELIST which contains a list of the primary and standby CS hostnames in the Commcell, is it no longer necessary to use proxies for all clients to connect to the active Commserve in a CV Failover and LiveSync setup?
Can I set up the LiveSync without the Network Topology to use these proxies and just trust this additional setting to make the client connect to the active CS?
Are there any pros and cons?
/Patrik
Best answer by Patrik
