Data Ingest on Cloud storage from Commvault
  • 8 June 2023
  • 55 views
Badge +5
Hi Team, Could you please help us with below queries for Data ingest in Commvault:
  • Is custom meta data written to cloud storage, is there a process to do so?
  • How to find out about below Data Stats
    • Average data size
    • Variance?
    • File types
    • Are objects ever updated? Are deltas used?
    • Various levels of DPL and impact to storage used?
Userlevel 5
Badge +14
Hello @Lahari
All Commvault data is written in a proprietary format. The same format is written to disk, tape, and cloud.
Average Data Size - You can check this in the job details with the Application Size. This is the amount of data backed up from the client under a specific job.
Variance - I am not sure what you are asking, but in the Job Details we have a Savings stat which tells you how much of the data was deduplicated.
File Types - This would depend on Agent the backup is for, but for say Filesystem, I do not believe we have metrics on what type of files were backed up. For lets say a SQL agent, only the SQL files are backed up.
Are objects ever updated? Are deltas used? - Files are modified with deduplication and micro-pruning
Various levels of DPL and impact to storage used? - Can you elaborate further on this question?
Thank you,
Collin
