Hello team
Where i can find info about how “last seen loaction” mechanism works?
What adapter will check?
WHat happen if user enable VPN?
View originalHello team
View originalThat said, the docs don’t cover the details you require, so I’ll get some more information for you.
My pleasure!
Confirmed for you, straight from dev:
Track location by IP address via whatever adapter can reach the internet
If you are using a VPN, we would potentially assume the laptop is wherever the VPN lives (though it depends on how much the VPN does, for example a VPN might only act when a name can’t be resolved, but not for EVERYTHING).
Let me know if this helps!
Thanks for help!
