How Commvault checked laptop location
  • October 24, 2022
  • 91 views
Hello team
Where i can find info about how “last seen loaction” mechanism works?
What adapter will check?
WHat happen if user enable VPN?
Best answer by Mike Struening
My pleasure!
Confirmed for you, straight from dev:
Track location by IP address via whatever adapter can reach the internet
If you are using a VPN, we would potentially assume the laptop is wherever the VPN lives (though it depends on how much the VPN does, for example a VPN might only act when a name can’t be resolved, but not for EVERYTHING).
Let me know if this helps!
@Dmitriy , I believe it is via its IP address.
https://documentation.commvault.com/11.24/expert/4500_tracking_location_of_laptop_client_from_web_console.html
That said, the docs don’t cover the details you require, so I’ll get some more information for you.
  • October 25, 2022
@Mike Struening Thank you very much I would appreciate it
My pleasure!
  • October 25, 2022
Thanks for help!
Anytime!
