Is there someone use Migration Assistant tool to migrate Edge Chromium User favorites ?
It seems the migration Assistant Tool only include IE favorites but not the Edge one.
Thanks for your help
Best answer by somesh
View originalHi,
View originalHi
Thank you for the question and welcome to the Community!
I’ve been reviewing Documentation Components Migrated by the Migration Assistant for Windows Computers.
This describes Internet Explorer Settings that are included in the migration.
Edge is not included, so this looks to be expected behaviour.
Stuart
FR25 onwards, support for Edge, Google chrome and Mozilla Firefox is there in migration assistant.
Thanks for this information.
Is this version is already available for production or still in beta ?
General Availability date FR 25 was November 15, 2021. so yes its available.
I’m also working with
Stuart
Sorry to reopen this ticket but since the upgrade from 11.24 to 11.25.19, when we try to restore user information with “Migration Assistant” , we receive this error message :
Error Code: [23:93]
Description: Error in initializing the mapping file restore. No mapping file found and users choice allows only map-based restore. Nothing to restore.
Source: wpwmslas01, Process: clRestore
Is this linked to new version ?
Also, i checked the logs and i don’t know if the migration tool use this path to migrate Edge Favorites :
Sending source path '\{20d03aa2-7726-42d8-8381-fdda7a8a1c47}\SmartContent\cssf\schmitz_l\%LOCALAPPDATA%\MicrosoftEdge' with strip level 5
But if it is, the correct path is Sending source path '\{20d03aa2-7726-42d8-8381-fdda7a8a1c47}\SmartContent\cssf\schmitz_l\%LOCALAPPDATA%\Microsoft\Edge' with strip level 5
There is a backslah between Microsoft and Edge.
Can you provide the case number here once you do?
Here is 220211-333
Hi
Just checking a few thoughts.
Which clients have been updated to FR25?
You will need to update both the source and the destination clients.
Before performing a migration, I would like to check that you have also performed a new full backup (with FR25) on the source client so that all the data is captured before attempting migration.
Stuart
Hi
Stuart
Both clients have been updated (source and destination).
New full backup has been done on the source computer.
Still the same error.
Hi
Ok, thanks for confirming, we need to check this further.
I’ll track the support case as that’s the best way forward now.
Stuart
