Lab Commserver VM ( Commvault v11.32/Server 2019 OS ) has high CPU and memory usage when ideal
  • April 14, 2024
  • 82 views
Anyone have setup a lab Commserve on a virtual box VM. Mine has a very high cpu and memory usage despite no backups running.
I wonder if you guys have setup one before and was able to tweak so it does not consume a lot of cpu and memory even when its idle
This is Commvault v11.32 with the latest hotfix pack already.
This is running Server 2019 with SQL server 2019 as the SQL backend for Commvault
running this on a makeshift virtual box VM
Thanks for any tips and tricks you can provide
Chris Hollis
@mach123
What are the specs of the VM? Does it meet our system requirements? (and the requirements for each component you have installed on it… e.g. is it a Commserve + Media Agent?)
CS H/W Requirements are here: https://documentation.commvault.com/2023e/expert/hardware_specifications_for_commserve_server_01.html
MA H/W Requirements are here: https://documentation.commvault.com/2023e/expert/hardware_specifications_for_mediaagents.html
We have a couple of regkeys we can utilise to prevent certain processes from consuming cpu/memory but it might negatively impact the software..
Any particular process consuming the most resources?
Also make sure SQL 2019 is patched.
Chris
