Hi, in the advanced restore options in BOL.
It says : Restore of database fails if exclusive access to database cannot be obtained. In such scenarios use the Drop Connections to Database option to drop all existing connections to the database. By default this option is set to false.
But at my customer this option is enabled by default !
Where can you change this to OFF by default ?
Thank you,
