OceanProtect X8000 as a NAS Disk library best practices
  • Jun 29, 2024 7:36 AM UTC
  • 397 views
The Configuration scenario as follows, two RHEL Media Agents with OceanProtect X8000 as a NAS as the Disk library, what is the ideal block level to be configured in the storage, and if there is a detailed configuration steps for the same.
Hello @Nawras Haddadeen
Commvault does not have white papers for each storage vendor and if that does exist that it would be written and managed by the vendor its self and not Commvault. If there is not one published by them Commvault's recommendation is to use the default settings.
Kind regards
Albert Williams
Kind regards
Albert Williams
