If the job is on 80 % thewn commvaul;t start over again with the job. If I look in the log the backupo is finished on oracle site. Commvault don't recieve the message that the job is done.
It occurs after we do the upgrade to the new version 11.25.14.
Any body the same issues?
Hi @marco1975 hope all is well (and welcome to the community)!
Has this started immediately after the upgrade (and worked every time beforehand)?  What do you see in the job details?
I spoke with our head of Unix support who said this is not a known issue.  He advised opening a support case to have his team investigate.
Once you do, please share the case number here so I can follow up accordingly.
Hi Mike,
I have a support case opened 220124-275. I have send some logging and they wil have a remote session tommorrow. Keep you updated.
Cheers marco
And is has been started after the upgrade.
Thanks, @marco1975 .  I’ll keep an eye out!
Sharing case resolution:
RMAN-08591: warning: invalid archived log deletion policy
released channel: ch1
Advised to add the below additional setting in Oracle client and retry
key: nDisableCVSessionServerMode
path: OracleAgent
type: Integer
value: 1
Backups are running fine after application of key
